Solitaire
I've just checked out your boat. You have a boat that is 23 ft overall with an 8ft beam. It is powered by a 4 cylinder petrol engine of not much power with a semi dispalcment hull. I would suggest that it was principally designed for use on rivers and therefore sea conditions and weather will be a consideration. Particularly as you say, you are inexpereinced. If you are thinking of doing the trip in anything over a F4 and the wind is S/W with the tide running out of the Solent - don't do it!
Plan your trip very carefully and seek advice and check the tides very carefully on the way back. I don't want to frighten you but I'd not do this trip alone at this stage.
<hr width=100% size=1>
