noelex
She enjoys teaching anyone who is interested, but you will have to bring chocolate and single maltDoes she give lessons![]()
Where do get the covers from?
Though never had a problem with chafe, marlow d12 max is really tough stuff.
Thinking yesterday maybe splicing some dyneema to the halyards so if any chafe does occur it's easy to replace rather than eventually have to ditch the whole halyard.
The Dyneema cover is actually quite tightly woven, smooth and low friction. Initial results are very promising, but it is early days.
Thanks for clarifying.Oh, I saw it backwards.
View attachment 80822View attachment 80823View attachment 80824
Well, whadaya know!
First attempt to upload pics with new laptop.
So here is the soft shackle I tried (a link on the WWW)
Any comments?
Good, bad, wrong size etc etc?
Get a soft shackle!)
Any comments?
She enjoys teaching anyone who is interested, but you will have to bring chocolate and single malt.
.....Any comments?
Yuck! Put a soft eye on the end of your sheet and use a soft shackle. Stronger and much safer.View attachment 80822View attachment 80823View attachment 80824
Well, whadaya know!
Any comments?
Yes, it's a good set up I have used similar in the past, saw it first in PBO a good while back.
A timely reminder to look at it again for next season - saves pulling through acres of sheet on a dinghy-like set up and does not lock up solid.
PS.
I would set up the locking loop so it physically can't move back - Either close up the holding loop or seize the locking loop in position.
Vulnerability to chafe is the largest drawback of soft shackles versus stainless steel shackles. My wife is the rope guru on board and makes all our soft shackles. Where chafe is an issue she has started to use a Dyneema cover. As well as an extra layer providing chafe protection, the cover material is very tightly woven which seems to produce a result that is highly chafe resistant compared to other ropes (but still not as good as stainless steel obviously). However, we have not been using this combination long so it is a little too early to tell.
Here is a photo of the cover on several Dyneema loops, skilfully secured by weaving in the ends. The cover is onthe right, bare Dyneema on the left. The same cover can be added to soft shackles, or the cover can completely encase a Dyneema loop if needed.
Paul, do you have a reference for the way you spliced the LFR into the shackle? I'm planning to make some up for a preventer and the only ref I have found is on cruiserforum, I was initially planning to just incorporate a locked brummel into the soft shackle...I have made some with low friction rings in them and some without. I don't use them much, but i do use a set of four, with low friction rings, for the cruising chute tack line.
Well, whadaya know!
Any comments?
have a look at thisA problem with a sheath is how to finish off the cover,
That's not a soft shackle. Rather than that, use a cow hitch with a single line.
