Fr J Hackett
Typical range of a yacht under electric propulsion is between 20 and 50 miles, OK at a pinch for a long weekend coastal but could be a considerable handicap offshore unless you are in one of the worlds windier places when you don't need a motor anyway which is the essence of a sailing yacht.Yes, but this is the same between diesel and electric. Eventually sailors run out of wind.
You’re confusing unlimited range with perpetual running. Most boats move once a week and could easily recharge in between. My point though is that if a diesel and an electric motor into the pacific, the diesel may never be seen again because it’s range is definitely finite and a fuel refill depends entirely on others. The electric may take time but will refill and motor without outside help forever effectively (and the components will last longer with no maintenance too).
The only issue is most sailors are in a hurry due to work. That doesn’t alter the fact that solar electric has infinite range while diesel does not.
