jakew009
HeyEvening Jake, hope the refit is going well? I’m really enjoying following your journey and as I mentioned previously, you have provided a wealth of information that continues to aid me with my own 805, and for that I am truly grateful. With that in mind, I was hoping I could pose another question and ask a couple of polite requests?
Firstly, I’m looking to order some Roca W12 Wiper Motors and wanted to check whether you fitted the 42mm or 68mm bulkhead version? Also, can I ask, did you fit Roca Pantograph Wiper Arms for 72 Spline Shaft (454mm-591mm), and if so, what size wiper blades did you fit? Were they 405mm?
Secondly, now that you have fitted the solar panels, would you be able to share some images and detail of how you attached them, location, connectivity etc?
Lastly, you had mentioned in an older post about the possibility of sharing a wiring diagram of your new installation. Is that still possible, given you clearly have a lot more knowledge than me and I’m really interested in learning more about what you fitted and how you wired things together. Of particular interest is the Victron equipment.
As always. appreciate all your help and thanks in advance.
Yes I will update this thread again soon, working on upholstery and vinyl wrapping atm
For the wiper yes you want the 68mm version. I tried the 42mm version first and it didn’t fit. Well it did fit but then I realised it has to sit at an angle and it’s then not long enough.
Then you want the biggest panto arms for the W12s and 560mm wipers. Any longer doesn’t really fit and also the motors will struggle to swing them. 405mm wipers will be too short.
Here’s some links I got for someone else
These wipers: Roca 12 Volt Window Wiper Motor W12
These arms: Roca Pantograph Windscreen Wiper Arm
And these blades: Roca 560mm Window Wiper Blade and Adaptors
It's not exactly a straight swap, have to do some fibreglass work, see here: Small refit Merry Fisher 805
I also really recommend getting one of these, they work brilliantly Amazon.co.uk
You will have to pull some extra wires through the ceiling but that’s easy.
I forgot to take photos of solar panels so far but they are 2x200W semi flexible panels going sideways.
Cable goes in through a gland I 3D printed and then down the rear pillar and into the battery compartment. You can access the area by taking one of the factory fit speakers out.
On the wiring diagram yes, just need to make it into a shareable format. Will do that soon.
