Plevier
Hello Ray
Well done on brilliant detective work. I'm afraid i haven't been back to the boat yet to try anything.
However I agree with everything you've posted until you get to the NMEA details where I just don't know. Mine is connected to an Interphase 7CVX which according to the manual outputs NMEA standard 0183 or 0180. I don't know the difference. I'll have to go through the setup routine for that too! At least I don't have the Seatalk conversion complication.
On its input the 7CVX recognises GGA and GLL, it doesn't mention ZDA in the manual.
How does one view what sentences are being sent?
I can confirm the radio always shows the time of the internal clock, whatever I do to its settings and the GPS.
The Skanti manual on p20 note 5 says "If a GPS is connected, time and position are automatically inserted." and in the distress call set up format on p23 it shows you getting the chance to input lat, long and time if GPS is not connected but skips all of them including time if GPS is connected.
My suspicion is that the GPS time connection will override the internal clock and use a UTC time for a distress call but the handset always displays whatever local time you have selected, never GPS time. I think the only way to check would be to make a DSC distress call.
It's a pity the Skanti manual is so totally devoid of specifications and installation instructions. I can't find anything downloadable on teh Thrane & Thrane Denmark website. It sounds as though your local agent only has limited info too.
