poter
I have single line reefing on Shady with a first & second reefing line brought back to the cockpit. After a few trial & errors I think we have cracked the reefing procedures & got the lines to run reasonable smoothly.
But:
Is there any way to make the reefing lines run easier? there seems to be a lot of friction & I have set it up as per the manufactures details, would better/more expensive blocks and organisers be the way to go?
Also would a solid boom vang eliminate the problem of using the topping lift every time you need to put in a reef?
poter
But:
poter
