Simrad S12 Log does not like getting wet
GrahamC
21 Oct 2001
Edinburgh.Scotland
The damm thing works in fresh air but when fitted into hull fitting no reading on display. Slipped the boat and impellor spins freely. Its been back to B & G twice and returned a ok and so it is in fresh air. Any clues (no its not back to front in the tube) as to whats going on /forums/images/graemlins/confused.gif
Regards
Graham C
Thistle
2 Oct 2004
Here
Silly question, perhaps, but does it get far enough down the tube, so that the blade tips are clear of the hull fitting?
fireball
15 Nov 2004
If it works perfectly well off the water then there is something preventing the impellor from turning when it is in place - I assume you've tested in-situ but out of the water? If so, then check the hull for obstructions.
GrahamC
21 Oct 2001
Edinburgh.Scotland
Thanks gents but it is clear of the hull and should work but dont. I am wondering if its a problem with the magnets not being powerful enough once immersed
Regards
Graham C
