Sidepower Bowthruster
Gryphon2
12 Oct 2009
I have a small oil leak from my thruster. Any idea how easy it is to replace the appropriate seal? I assume the boat needs to be out of the water?
TerryA
17 Mar 2019
Another problem. Unused for a while. Power is good, solenoid is clicking like mad for either direction but motor doesn't run so I assume a motor problem. Can I remove the motor from the bracket on top of the tunnel while I'm afloat or is that a recipe for disaster?
Caladh
25 Oct 2009
Out there again and no longer dreaming
Yes you should be able to remove the motor. I’d speak to Osmotec in Hamble for further advise.
TerryA
17 Mar 2019
Thanks for your reply. I'd just found a motor overhaul instruction sheet on the old inter-web. Twice assured with pictures to guide me I'm set to go.
