Show us yer lumps
SORRY to bring in Fred Drift.......BUUUUT ...... what is a boathook used for in the engine room ??
It's a spare thoughtfully provided by Ferretti. There are 2 boathooks on deck, stored on port and starboard side decks. If we were to lose one, always a possibility with some of the guests I have on board, then we could replace it immediately. You use a boathook pretty much every time you moor stern to in the Med to handle bow lines so its an essential piece of kit
Aren't petrol big blocks lovely...? :)
I lick these mothers clean every morning. MAN V12 diesels
Tsk, no gold plated rocker covers Mike, how shabby....I remember a thread of ten years ago or so by TCM on this subject where he was trying to buy them from MAN, I can't remember if he was successful or not.
On a serious note, I am surprised to see so many engines rooms with fluorescent lighting as the primary light source. It is obvious when an engine is running but often engines rooms have other plant with spiny things working away and there is a real danger of putting your hand on something that looks to be stationary when in fact it is just in sync with the fluorescent tube.
Yes I've failed again. We did look at an Elegance 64 last year in which the MAN engines were painted gold all over which I thought looked quite fetching
Never thought about that risk with fluorescent lights although on my boat they only work on 220V so its unlikely the engines are going to be running when the boat is hooked up to mains power
M, as you already know, I think your F630 is indeed a great vessel, but I must say that fitting AC-only lights in the e/r without connecting them to an inverter (hence requiring either shore power or genset to turn them on) isn't up to Ferretti reputation....
Sausage machine...
Air compressor
Genset
Hydraulic pack
Power take off
Gyro motors
ER fans
Seriously though, if you had someone doing maintenance in the EB they might put their fingers in to something that was moving e,g, a prop shaft coupling spinning when it appears not to be.
There are also 24V lights around the engine room as well which actually are perfectly adequate. The 220V fluorescent lights are a nice to have rather than essential and I often forget to switch them on anyway. Having said this, you can have as many lights as you want over the top of the engines but you still can't see easily under the engines and into the dark corners so I tend to have a torch with me as well when I go down there. Maybe Lumishore should introduce some under-engine lights which could be fitted on the inside of the hull facing upwards:D I expect that jfm is going to tell us he's got these already:D
Sausage machine...
Doh! How could I not think about it?
That and the chain saw (as I recently learned) are obviously at the very top of boating essentials list... :D
Jokes aside, I do see your point in principle, but I've seen fluorescent lighting used also in some much more dangerous environments, like hazardous chemical plants.
I would think/hope that anyone going in an e/r takes more care than just relying on what is obviously visible, before touching anything....
Thanks and yes that's the one ... bought her in 1991 and was my day-to-day car for nearly 15 years... these days she is spending most of the time in a dry garage after I spent a small fortune (and loads of time) restoring her to her former glory....
Beautiful - a work of art those XJs! Over the years I had 2 x XJ6, XJ40, XJ-R and XJ-S with the V12. Sadly had to dispense with the luxury of a car and a van, so switched to V8s in the form of 2 x Range Rover Classics, a series 1 Discovery and now a P38 4.6 on LPG. Would love another classic Jag, but neither the time, nor space to do it justice - and in my experience they like to be used or all the rubber bits start to perish. :)
Rust was a big killer on these esp around radius arm mounts but get a good one a with as RB said good bushes and she'll ride as well any rolls
I went from these great sounding but 'thirstier than Ireland' lumps (7.4l V8 350HP)
To these far more frugal diesels
I'm just sorting a pair of these, trying to obtaina new dry turbo is real hard work so look after your holset h2A as there obsolete now.
Look nice where on the hamble are you? Who fitted them? Nice bits of kit.
