Mister E
For the doubters check up on Toroidal transformers.
I spent a whilst living in a caravan in a dark cold distant winter, I learned flaking my electric cable along the freshwater hose supplying my internal tank produced enough heat to defrost the fresh water hose some nights it didn’t freeze other nights it was a little earlier.
A little hose rerouting and more flex on less exposed hose and my supply hose rarely froze.
So yes coiled wires are not good, unless used correctly![]()
Or was pulling more current water pump, heating, hot water, fridge etc.Interesting .... I have standard sized cable to my boat at home and coils on the pontoon ..... in winter there can be over 1m of snow ... but during the accumulation of snow - I never see any evidence of coils melting snow ....
I have a long power cable from house laid out down to the 35ft Mobile Home - which then has lead off to BBQ area and decking - then to boat ... that power cable also never melts snow round it ...
I can only assume you may have had a lighter grade of cable that was warming up due to its smaller section ?
At large events you'll see the power leads unrolled from the drum and layed out in a figure 8. Reduces the heating, plus if someone pulls a cable it neatly uncoils.For the doubters check up on Toroidal transformers.
They are uncoiled purely to prevent overheating as there is no issue with induction on a mains extension cord.At large events you'll see the power leads unrolled from the drum and layed out in a figure 8. Reduces the inductive load by having nearly equal and opposite loops, plus if someone pulls a cable it neatly uncoils.
I forgot that such cables often also carry data signals, which is the reason they suffer from inductance. I'll edit my post.They are uncoiled purely to prevent overheating as there is no issue with induction on a mains extension cord.
