Refueler
The windlass will hold the chain once the anchor is set-----a bit like putting your auto gearbox in "park" but the brake is used to stop too much chain running out while anchoring. One potential problem is overheating and brake fade which can result in the entire chain running out. If there is too much energy built up it can pull our the stopping bar in the chain locker and you lose it.
The Ships windlass has a dog clutch that is only used when retrieving or walking out the anchor. It is never left engaged when anchored. Therefore the windlass never holds the chain for anchoring. The brake performs that function.
Incident Irish Sea - gale force conditions on a 20,000 ton tanker, ST Partula, in ballast ...
I was 3rd Officer and sent forward with Bosun and AB to anchor ... (I did question the Master if such an act was suitable in the conditions - but was instructed to do it ...) The pilot service into Mersey was suspended due weather ... usual practice was to steam / drift near Isle Of Man but this Master was new and TBH - a complete blithering fool ..
I was told to 'let go' the anchor to 6 in the water ... a rather daft order - but I complied. This means the act of walking out under power of windlass to the waterline and then brake on. Unclutch the windlass and then on order of Bridge to release brake and let her 'run out'. Normally this is no problem and chain will often stop running after short length out ... ship moves and pulls next length out ... When you get to desired schackle ... you set in water or on deck as ordered. Screw up brake and wait for chain to show she's brought up and steady. Deadman on ... check brake is secured and that's it.
But this time as feared - ship was under influence of gale force winds and that chain flew out the locker throwing s**t and rust everywhere, no way could brake be used to hold it - in fact flames were coming of the gypsy. Master failed to hold vessel on engines ...
What to do ? You have to think quick because 11 shackles soon gets out !! I shouted at Bosun to let her run as free as possible but as soon as chain slacked to get that brake on as hard as possible. We managed to stop the chain just before bitter end ... which would have meant chain locker damage. The gypsy was hot even with the rain and wind ... it was winter ...
I called via Walkie Talkie to bridge advising that chain was finally under control - but we had at least ten and half shackles out ... to be shouted at and ordered to heave back to 6.
Imagine this ... me - young guy nearly killed by this along with Bosun and AB in blinding rain and wind ... middle of the night ... freezing cold ...
We eventually got back to 6 in water ... and all secure. I reported to bridge that I was afraid the anchor was not holding - to be told we were to stand down and I was to report to bridge.
I went up to the bridge to be shouted at and reprimanded for 'my' nearly losing anchor and chain ....... Everyone else on the bridge were dumbfounded ... even the 2nd Officer tried to tell Master that in fact I saved the anchor and chain from breaking out.
Needless to say within less than an hour - I was in my cabin trying to get to terms with it ... when I felt the unmistakable vibration of ships engines and her moving. She had dragged so bad - there was no way to arrest her and she had to apply half ahead to even get anchor up ...
