Neeves
Maybe a 3/8th" shackle is too strong, some manufacturers only make 3/8th" as their smallest - some go down to 3/16th" (to a G80 specification) - and if you are using 8mm chain then as the WLL is unlikely to be ever achieved - why use 8mm chain, 6mm would be perfectly satisfactory (with a decent snubber)It looks to me from the failure loads that the shackles/chain/etc failed at loads greater than likely to be found on my 30ft lightish boat. Or is that too simplistic an approach? I must admit, very few of the shackles on my boat are ‘name brand’, merely the usual generic 316 stuff from a chandlery.
The trouble is
A good 3/8th" galvanised (so alloy - not stainless) has a WLL of 2t, which reduces to 1t if side loaded (I have tested this its correct). These shackles sometimes are called G80 shackles.
A shackle of unknown origin, and whose testing protocols have never been tested, might have a 1t WLL, reducing to 500kg if side loaded.
No issues - but if you are using G30 8mm chain its WLL is 750kg (and, say, 75m of 8mm chain is not cheap) then your rode is as strongs (or as weak) as the weakest link - your nefarious shackle. A good shackle cost a fraction of the cost of your chain.
Its simple stuff - a 1t WLL is not likely to be realised, nor even a 500kg WLL - but why save a few pence.
The trouble is - there are a limited number of manufacturers making G80 shackles, or trustworthy 3/8th" shackles with a WLL of 2t. Crosby, Peerless, Campbell and Yoke - it is possible to check them (all reputable companies having been in the business for decades).
There are many suppliers of nefarious (or perfectly good) shackles - but would you reply on Lidl to buy from the same sources next year, have Lidl tested them - are Lidl accepted as a supplier of lifting equipment.....etc
There is no in between quality - you either put yourself out, a bit, and sleep well and go overboard in the specification or you opt for the shackle, possibly, designed for securing the pet dog.
Jonathan
