VicS
Monel is an alloy of nickel and copper and little iron (65,33,2%) Although I can't find any electrochemical data for it I would assume that it is not suitable for use with galvanised steel. It is the correct material for seizing stainless steel though.
Regarding galvanised shackles my experience with those from chandlers is that they are absolute rubbish. The pins seem to be very soft and wear to not much more half their diameter in a season. Also the OD of the thread is greater than the pin diameter, presumably because the thread is rolled on rather than cut, with the result that the head end is a slack fit in the hole. I think you will fit that the shackles used for lifting have a shoulder below the head so that they are a decent fit and may have cut threads as well. You would be better off using this type of shackle even though they are not galvanised. I think there is a British standard that covers them.
Use the thickest gavanised wire you can bend and twist for seizing. Do not be tempted to use two, or more, thinnner strands as they will be little better than one strand.
Lake sailor is right in not mooring to the ring, at least with the buoy he has. Some may be suitable but those I have looked at are not according to the suppliers.
