JumbleDuck
I wouldn't trust my cleats for towing anything bigger than a light dinghy.
That's got to be a worry in harbour, surely?
Reality. My sail boat is not equipped to tow another boat. In bad weather, life threatening I am not sure I could. Tow a 30 or 40 ft sailboat or motor boat of a lea shore. .
Many years ago, we wanted to jump start a diesel Land Rover (short base, so not all that heavy). We used a chain with a forged hook on the end as a tow rope - far stronger than most of the kit suggested here, but of course, zero elasticity. The towing vehicle went off with a bit of a jump, there was a loud bang and we found that the hook had straightened!
Many entertaining examples of shock loads doing unwanted things - frequently including rapid removal of major mechanical components - can be found with a quick YouTube search on "towing fail compilation"...
No so entertaining when the flying end plus lump of metal hits someone on the head and kills them.
Most of the fiascos I've seen with one boat towing another, it's a quick tow through the harbour entrance against the tide. When it's likely to be a matter of passing whatever rope is handy and using it as a tow line maybe a boat length or two long. Usually light winds or we'd all be sailing, so flat water.
Until the wash from some other boat catches you out.
As Thinwater metions, managing the slack helps, don't let the line go completely slack, and have some rope to ease as the wash hits.
We get towed to and from the racing area sometimes in boats weighing maybe a ton all up? We find a useful technique is to just take a turn around a cleat or post, then hold the rope by hand. Let it surge a few feet if you get hit by wash, pull in a few feet to avoid slack building up, try to maintain a fairly constant load. As well as not breaking things, it helps both boats steer.
Setting up for a long distance tow would be a different thing. As would any sort of max power emergency towing.
