PaulRainbow
Battery settings in the app at the bottom
Thanks Mark, i am aware of that menu option. But, clicking that alone does not actually calibrate the monitor, it simply zeros the current reading. If there really is a 20a current drain the monitor will zero, based on that, so the drain will be masked. To use the calibrate option it must first be established that the monitor is reading incorrectly and that there is in fact zero current flowing through the shunt, either by disconnecting the loads, or checking with an ammeter.
There is not usually a need to calibrate the current on a new install and i've never had to do it because of a battery change. For new batteries, the only thing to do, usually, is to set the ah, if needed.
