CaptainBob
One of my seacocks is pictured below. A bit of weight on the elbow caused it to break off.
In the picture it was connected 1 -> 2 -> 3 with the broken part snapped off part 3, with its threads remaining screwed into section 2.
Part 3 is actually in two parts - it looks like it's an adaptor to take the hose attachment down to the correct thread size... and I _think_ it's a different metal to the other parts.
When I scratch at the metal of all parts, inside and outside, it all looks lovely and yellow except for:
Part 3 and it's snapped off bit, in the vicinity of the break, which looks like copper pink and shiny when I get through the top surface.
_Some_ of the threads (female) in Part 1 (the skin fitting/seacock), but not the metal deeper inside, and not the seacock 'door' etc etc.
All investigation of the skin fittings on the outside shows nice shiny yellow metal.
Here's the picture:
So what to do? Each of the seacocks on the boat is different, no two are alike. Some are more substantial and silver in colour.
Boat is a 1978 Nauticat 38. Perhaps the skin fittings are original, they mostly look glassed in place, so I assume at least those ones are.
Do you think I need to replace the lot? Or just the broken one? Or just the broken part of the broken one?
Is the dezincification which I assume is what has happened likely down to a bad choice of part (two different metals), or poor connections to the anode (which is present and does look wasted) or just time?
Thank you!! Sorry for the essay!
Here's the picture:
