Little Dorrit
I have a 3/4 inch ball valve as shown on the attached.
This is for a sink drain which due to the height and placement of the ball valve is not draining properly as a result of there being little run on the waste before it reaches the ball valve.
I plan to remove the 90-degree bend and replace it with a bend with 135-degree or close to improve the water flow out of the sink.
I have tried to remove the bend only but it's proving difficult (although I haven't) hit it with a mallet in fear of doing serious damage to the skin fitting. It appears to have something resembling horse hair around the tread?!
If possible I would like to remove the seacock and leave the skin fitting in place and then either replace the bend or replace the entire seacock with one the sits closer to the hull.
Can, as best you can from the attached, tell me how best to remove the seacock without damaging the skin fittings?
Once removed will I be able to screw the ball valve down more or will I need to cut some of the thread off the through hull fitting or should I replace the entire fitting.
