Nina Lucia
Shamaya
Friend just advised to hang bucket from the stern, any thoughts on that?
A method I have used is as described and illustrated in 'Cruising Under Sail' by Eric Hiscock.
Rig the spinnaker pole as a sort of temporary bowsprit so it sticks out about 4 or 5 feet over the bow.
The main buoy rope/chain is brought over the bow roller and secured on the sampson post/bow cleat, as normal.
Rig another line from the buoy, through a block on the end of the pole and brought back to the foredeck where it is belayed. (Hiscock calls it a 'bullrope')
Adjust the bull rope so that the buoy can come near the bow but not touch it.
When the wind and tide are together the boat lies to the main buoy rope, as usual, and the bullrope does nothing.
When the wind is opposed to the tide, and the wind is strongest, the bullrope comes into play but the load on it is quite light.
I have used this during a NE force 9 on a visitor buoy in L'Abervrac'h with a strong flood tide and it worked fine and protected my topsides from the attentions of a barnacle encrusted buoy. I didn't use it once in a similar gale against tide situation in Omonville, where the buoys are big and barnacle encrusted, because I was too exhausted to set it up, and suffered some bad scratches on the topsides.
Rather than risk bending an expensive spi pole, I'd have tried a length of stiff plastic tubing over the chain or rope ( plastic 'food grade' tubing as supplied by chandleries ); if long enough to reach from buoy to near the boat's stemhead, the stiffness should keep her off the buoy.
