duncan99210
If you take a lightening strike to the boat, it's probable that it'll take out most electronic devices, switched on or not. That's because the energy in the strike will induce currents in the electronics high enough to burn out some components. Putting things in the oven may protect them but it's not a given.
There's also a good chance that it'll take out elements of the wiring system for the same reason. A friends boat was hit whilst ashore, everything turned off. The strike took out all of their electronics, much of the domestic and engine wiring and a couple of through hull fittings for good measure. That said, others have had near misses or lighter strikes that only took out some of the fixed electronics and left everything else undamaged. So, much seems to be down to luck as to the strength of the strike.
I seem to recall someone on here posting about taking a strike in the Solent: they were motoring at the time and the engine carried on working but most of the rest of the electrics and electronics on board were wiped out.
My drill for lightening is to avoid if possible, if not I'd shorten sail, sheet in the mainsail to minimise any damage a gybe might cause and start the engine: I'd then have power should we were to take a strike. And if time permitted and I remembered, put phones and the like in the oven.
