Sailing around the world on a budget
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
In many places putting local ice in drinks means the following week being spent in the toilets bent in two by intestinal disease :(
Probably better to use bought ice in a freezing mixture to freeze bottled water (assuming you can trust that...). We used to buy block ice intended for fishermen and break it up in the cockpit bare-chested to get full benefit...
BobnLesley
1 Dec 2005
Aground in Yorkshire awaiting a very high tide
... Years ago I tried taking on holiday a cassette of the sound of ice clinking in a glass to see if it enhanced the sensation of drinking warm G&T: not much!
Way back when, we had friends in the eastern Med without a fridge (actually without much of anything) who had and swore by a set of plastic ice cubes; the theory was that while these didn't cool the drink, the sound that they made clinking in the glass deceived your brain into believing that it was cooler. I guess it worked, or otherwise on a Pavlovian principal?
zoidberg
12 Nov 2016
I'm hoping that habit will spread....
bergie
2 Feb 2021
lille-oe.de
Avoiding ice is a good idea, as is not eating uncooked veggies in a restaurant. Or at least consume the drink quickly enough that the ice won't have a chance to melt 😆
We actually do carry an ice cube maker on our boat. Consumes only around 80W, so while we don't have the power budget to make ice every day, it is a nice thing every once in a while. And the ice stays good for a while in a thermos flask. We tell ourselves that the ice maker is a fallback system for the fridge...
The first unit broke when we were in Scotland, but the manufacturer was gracious enough to make us a return label to send it from Northern Ireland (our next port), and then send a new unit to us in Galicia when we were a bit longer in a marina.
lustyd
27 Jul 2010
Multi purpose vacuum pump also ideal for aircon, some people use a vacuum cleaner
It's sucking out no contamination
Pretty sure we’re talking about different things. Vacuum sealers for food incorporate a heat seal and use food bags and can be used for sous vide cooking as well as portioning and storing food. I also have a vacuum pump but it wouldn’t serve the same purpose.
Amazon.co.uk
lustyd
27 Jul 2010
" a vac pack machine on board."
Are they 12 volt, or would going into a Marina be necessary to operate the machine?
It’s pretty low power and only on for seconds so a small inverter would be adequate and well worth it. The trade off is the ability to buy pasta, rice, nuts etc. by the sack load and portion them down which not only is usually far cheaper, it means only a portion is open at a time to the air and critters so food tends not to spoil even if thrown in the bilges.
Snowgoose-1
2 Jun 2015
And ground beef on the rare side almost everywhere in the world.
Just watched a prog where 12 yr old is lucky to be alive.
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
I suppose these days we could have electronic transparent cubes that played a choice of sounds... fake ice, anyone?
dansaskip
12 Nov 2004
Various
seabear.uk
Whilst an advocate of the KISS principal, there are limits.
Our fridge died the day after we arrived in the Marquesa Islands and it wasn't until we reached Tahiti six months later that we were able to fix it; No, the main downer was cool drinks, though you can with perseverance learn to enjoy G&T/Rum cocktails/wine when warm, we never managed the same with beer;
you provide a good example here of why not to have a fridge -
they break down
Me I have long given up putting ice in G& T after all it only dilutes it 🤣 and cold beer well it just lessens the taste unless of course you like beers that are so awful that they can only be tolerate so cold you can’t taste them 🤣
Sea Change
13 Feb 2014
they break down
You can apply that same argument to every piece of equipment.
I think the key is to not let yourself become dependent on any potentially fragile equipment. Your fridge, watermaker, lights, engine, GPS, etc can all fail without warning. The thing is to not put yourself in a position where that critically endangers you.
IanCC
14 Oct 2019
Fridge, watermaker? On a "budget". 😊
Sea Change
13 Feb 2014
Watermakers are expensive and something of a luxury, yes.
But a fridge?? What kind of budget are you on that you can't afford £200 for an Alpicool?
You'll probably end up out of pocket by the time you've bought all the canned food you'll need 😂
Even the author of 'Get Real, Get Gone', who wrote vociferously about the perils of marine refrigeration, has fitted a small portable unit.
There's definitely a bit of a hair shirt mentality going on in this thread. Maybe there's a lot of people sat in a comfy home (no doubt one that has a fridge of course) daydreaming about taking off on a 1970s style adventure. Well if that floats your boat, fine. I don't think it's a rational choice
MisterBaxter
9 Nov 2022
It's not just the fridge though, it's the generation, storage and charge management capacity to keep it running reliably, then the cost, space and time involved in installing and maintaining it.
I think it's legitimate in a thread about cruising on a budget to explore the very cheapest end of budget cruising, which inevitably leads to discussion of simply doing without various bits of equipment.
Stemar
12 Sep 2001
ISTM that it isn't just the fridge, it's the extra power consumption, which means more batteries and more solar or whatever generating capacity.
We weren't crossing oceans, but we managed for years without a fridge, sometimes for a couple of weeks at a time without re-provisioning. Lots of tins, bottles and UHT milk.
Tranona
10 Nov 2007
Problem is that "basic" and budget" change over time. In the 60/70s basic may have been an old converted fishing boat or a pre war "pocket" cruiser and a Nic 32, Rival 32, GH31 etc would have been the height of luxury. Now those luxury boats are firmly in the basic and low budget camp. The point about the fridge is that even the most basic can afford a portable freezer and the solar panel to keep it running.
lustyd
27 Jul 2010
To be fair 200W of solar and a controller would only bring the fridge cost up to £500 max. There’s cruising on a budget and there’s choosing a needlessly basic lifestyle and it’s good to know which is which. Everyone is entitled to choose, but it’s folly to suggest there’s some nobility in going without. If that cost is out of reach then it’s very likely that a boat and food might also be too expensive anyway. Early in the thread people were discussing realistic budgets of £1000-2000 a month so saving £500 wouldn’t affect affordability at all.
