Neeves
I'd like something like this attached to standard harness, with the attachment point on the chest part of the harness.
Jonathan
Yachtsmen will be working with the deck under, behind & in front of them
so the chances of snagging the rear straps on a cleat or winch top are quite high
In addition, I do not fancy being towed along with the attachment point more at the waist rather than the chest
Possibly OK for going up the mast though
Horses for courses & obviously it suits climbers if they fall into it so presumably it is safe enough for them.
Climbers -I assume- are working with the hill at their face so the straps at the back should not snag,. Even sitting they should be OK. Yachtsmen will be working with the deck under, behind & in front of them. I " shuffle bum" along the deck in rough weather quite a lot due to my weak legs & age, so the chances of snagging the rear straps on a cleat or winch top are quite high
But how come I never had a problem in my parachute harness? See earlier post.
You must be jumping into a black hole to reach relativistic speeds, I would have thought. I have never parachute-jumped, but I'm pretty sure that Mr Newton would be qualified to look after me if I did. The force on my body from my harness would be the same as if I were suspended under the parachute hanging from a gantry with a blast of air at whatever speed one falls blowing upwards. If anything, I would experience very slightly less force when parachuting at its terminal velocity than when hanging in the harness alone in a static rig without a parachute above me.b. Once the parachute reaches steady speed (a minute tops), there is no difference due to the fact that you are still falling. General relativity..
I did say very slightly. I didn't want to be accused of sloppy arithmetic.. General relativity includes non-relativistic speeds. The central premise is that all non-accelerating frames of reference are equivalent. A sky diver at steady speed is non-accelerating.
The upwards wind would be about 15 MPH, accounting for only a few pounds, probably no more than the weight of the helmet. So no net difference.
I always thought that the acceleration due to gravity was about 120 ft/second/second up to the point where a human body reached a terminal velocity of 120MPH,( no parachute) so wind would not be 15MPH. So when parachute opens that is the speed at which the parachute has to brake the body- assuming that the parachutists does not open the chute straight away. But unlike a fall from height( or off a boat) it is a de-acceleration not a sharp stop( or buffered stop)
About 32 ft/second^2.
Once he is under the canopy, hanging, the speed will be 20-25 feet/second. Google it.
At the risk of upsetting everyone.
I am perfectly happy with my (mustang) life jacket with built in harness. I expect its quite similar to the many other varieties available.
My life jacket is in no way designed, suitable or intended to be used for fall arrest. I would not be happy to use it for climbing the mast or any other job involving the risk of a fall from height.
If I intend to work at height I will wear a full harness designed and fit for propose along with an appropriate fit for purpose tether.
When I am at the mast or on the fore deck of my boat. I require a harness which is suitable for fall prevention. which is entirely different from fall arrest. I have a suitably sized tag line or tether with what I believe to be suitable carabineers which are certified by my local H&S fro fall prevention.
The main principle for fall prevention to work. Fall prevention prevents someone from falling off the edge.
If a fall prevention system allows the possibility of an individual wearing it to reach the edge and be able to fall off.
It is not fit for purpose.
Actually you quoted before I had a chance to delete it after( see the timing !!) i realised i had it wrong. deleted now-55 years since i was at school
When I am at the mast or on the fore deck of my boat. I require a harness which is suitable for fall prevention. which is entirely different from fall arrest. I have a suitably sized tag line or tether with what I believe to be suitable carabineers which are certified by my local H&S fro fall prevention. The main principle for fall prevention to work. Fall prevention prevents someone from falling off the edge.
Truthfully, My boats system. Is not fit for purpose, due to lack of appropriate anchor points.
By Petzl. I'm sure it could be lightened up a bit for sailing; the webbing width is mostly for comfort. That is really what I would envision; this geometry, but lighter and integrated with a PFD. It would no look much different than a harness with leg loops, but it would actually work.
...If a fall prevention system allows the possibility of an individual wearing it to reach the edge and be able to fall off. ...It is not fit for purpose.
