affinite
Hi all
My brother in law is thinking about buying a Salder 32 as his first cruising boat. He has a couple (to start with
) of questions that Im hoping one of you Sadler owners may be able to help with.
1. Do you think that it would be feasible to attach a door between the forecabin and the heads/wet locker area in place of the standard curtain? When I looked at it I thought that there was enough room to hinge the door so that it would open into the same space as the existing saloon-heads door without them jamming each other (although you would just have to be careful when you opened each one to make sure that it didn’t foul the other one). ANother problem seemed to be that the opening does not have vertical and parallel sides – they bend in towards the bottom. I would therefore have to hand build the frame to fit the opening and the door but that doesn’t seem insurmountable. I think that there would also be an issue of ventilation but that could be assisted by having the bottom section either louvred or with large holes drilled.
2. The boat that I have been looking at (and quite a few other Sadler 32s) have a mainsail with boom roller reefing. My initial thought was that this would be a good feature, especially for shorthanded sailing but I have since read that there is a major problem in that you can’t use a standard kicking strap arrangement to hold the boom down and have to use some sort of claw attachment that hooks over the rolled up sail. I’ve also read that it needs 2 people to reef it – one to wind the reefing handle at the mast and the other to pull the other end of the sail to ensure that it rolls properly. Finally there seems to be an issue with performance because the foot of the sails tends to billow. Has your contact any knowledge/experience with the boom reefing system and if so what are his thoughts?
Thanks in advance
Steve (Affinite)
Thanks in advance
Steve (Affinite)
