RDL
The S37 is being surveyed today, and a problem has been found. There are slight cracks in the gel coat on one side, about 3 metres long by 15 cm wide. more than likely its had an impact at some point. This area is just above the chine and above the water line. The moisture level is quite high in this area due to water ingress.
The surveyor said that it can be repaired, but it would have to be done by a top guy in order that it could not be seen at a later date. Small gel coat repair has been detected on the other side, and one set of props badly pitted.
Please comment.
Please comment.
