Run aground at low water? Put your anchor out!
Ran aground yesterday..
Didn't put an anchor out,
Didn't call for help..
I was trying to get into my Mooring on an exceptionally low tide.
But you'd quite happily fit a radio and sail off knowing you weren't licensed to use it for the 101 other things it's good for apart from emergencies?
Yes, the two situations I might not remember stuff is a Mayday call and packing up at the end of the day.
it was on the boat when I got it
Does anyone else think it’s odd, or at least counter-intuitive, that you need a licence to use a VHF, but no license required to jump in, say, a 40ft, ten tonne yacht.
My non-boaty friends are always astounded to learn that there is no marine equivalent of the driving test.
So not one for going aground? Or a pan pan (or not quite pan pan) like the OP?
I think they are a good idea - I have checklists as part of my log/passage plan sheets so that I don’t forget stuff. But that is paper and lives at the chart table - not suitable for RIB use.
There are whole books of waterproof checks which seem sensible (but not £25 sensible!):
Amazon.co.uk
Although no idea if they cover groundings never mind getting the anchor out if you do.
The frequency of serious harm (death) to skippers who would be unable to pass the sort of test that is likely is very small. The frequency that those people harm others even less. Driving tests show that even with a testing regime you don’t avoid accidents. In fact, whilst it would be initially counter intuitive I suspect that any realistic test for say helming a rib would actually make matters worse - whilst some people who get no training today would get the bare minimum to pass the test, others who currently do the defacto minimum of PB2 would then do less. Meanwhile without any realistic prospect of getting caught many would continue to flout the rules whilst perfectly competent owners are funding some theoretical enforcement regime.
VHF operators are probably licensed the way they are for a mix of historic and international reasons. But misuse can have significant effects on other users, and effective comms is perhaps harder to achieve than many imagine.
The large number of radio checks on Solent CG CH16 just proves that people don't think before they key the mic.
My impression is the amount of VHF traffic is a fraction of what it once was, say 15 to 20 years ago.
Particularly we seem to be spared the intership traffic coming from club cruises in company and the like now almost everyone has WhatsApp group chats instead.
My sympathies. That happens to us once a fortnight if we’ve sailed east and are returning on the ebb tide. It gets quite exciting if it’s windy too. When the centreboard trips, it’s like driving a shopping trolley.
Neither used pro words "pan pan"
Quite correctly so, nothing urgent about running aground so technically they’re informing the coastguard. We didn’t use PanPan when a rope wrapped our prop in the Irish Sea either but I did call the CG to advise them we’d be sailing into Kinsale with no engine and to discuss the plan. In the end the RNLI helped us onto a mooring but that was four hours later so certainly not urgent 🤣
In these two situations I witnessed, the motor yacht being aground was not a routine situation nor was the rib that was aground but had now lost it's propulsion.
The wind was blowing F6 and the tide about to rise which would change the situation rapidly for both vessels.
Both needed help but there wasn't any immediate danger to life or the vessel. A text book "pan" situation. In aviation this happens too where pilots fail to use the appropriate pro word to alert the authorities. In one case I remember, this failure had a very bad outcome. We are taught about this in flight school to ensure we aren't shy about coming forward.
Avianca Flight 052 - Wikipedia
On the water, I've heard many calls from vessels that were clearly distress calls but without pro words. CG, quite rightly, responds to these with "what are your intentions". If you elevate & formalise the urgency with a pan or mayday, you'll quickly get all the help you need. It's what the words were designed for.
The radiotelephony message PAN-PAN is the international standard urgency signal that someone aboard a boat, ship, aircraft, or other vehicle uses to declare that they need help and that the situation is urgent, but for the time being, does not pose an immediate danger to anyone's life or to the vessel itself.
Pan-pan - Wikipedia
I completely disagree. There’s very little that could be done given they’d need to wait for the tide and whether they consider it urgent is their decision. I certainly wouldn’t. It’s unlikely I’d even be requesting help via the coastguard in that situation, more likely seastart in the Solent.
Many people these days call Mayday or PanPan at the drop of a hat, I think that’s more of a problem personally.
I'd never really thought before and maybe it's.a stupid question but - how do you set the anchor when aground? Winch it in? Hope it digs in itself?
Tension the rode from the boat end after the kedge has been rowed out or walked out, or a combination of both a fair distance. If the sea bed is dry, then dig it in by hand after walking out the anchor.
Did they have a problem getting the help they needed? I agree I would probably have made PanPan call in those situations (but then I also hope I’d remember to put anchor our reducing the urgency of help!). In busy radio traffic not using the right pro word might mean your message is missed.
Did the CG upgrade the call? It’s not unusual for me to hear a call to CG for engine failure be upgrade to PanPan - because 1. It gets other vessels attention, 2. It makes it less likely there is other not urgent chatter.
Whereas I would disagree. If the skipper thinks it’s a mayday or PanPan then s/he should not feel under any pressure from the judgement of the armchair listener or coastguard watch officer to be reticent about declaring such. It can be downgraded later. If there is an issue (and certainly I’ve not been aware of one) it’s that either almost always results in a lifeboat being launched rather than the many vessels who could have assisted doing so.
Clearly you are the expert on this whole subject, Mr RunAgroundHard. Have you put this into practice frequently🤣
