Rocna's bad press by video - anchor thread don't read if you don't like anchor threads!
TNLI
20 Jul 2020
The USN did not patent the design, as similar Claw anchors had been around for some time. It was mounted at the stern along with a large drum for the chain and dropped just before they literally smashed their way through the coral to get to the beach. They had a poweful winch to pull them back off the beach afterwards. I tried looking for pictures of the particular class of boat, but they are all of the bow section, but you will see it in films of the war in Pacific, and the claw anchor involved looks just like a Bruce.
When I did my first circumnavigation the CQR was the most common main anchor, with the Danforth as a secondary, but the Bruce was starting to gain on it in popularity terms, particularly with bosts from the USA and the reason was the the Bruce works on a shorter scope and does not get jammed if dropped in coral by mistake. Some of the Americans also pointed out that they regarded the Bruce as a copy of a US Navy claw anchor.
Wiki mention the use of the stern anchor and the class of landing craft it was fitted to in the design and manufacturing section of thos page:
Landing Craft Support - Wikipedia
TNLI
20 Jul 2020
I reckon that there's a lot more to dependable anchoring than just buying this year's, or month's, most fashionable anchor. I use a fishfinder, which I find invaluable for finding a good clear bottom. Clear of weed, stones, or anything else that might prevent an anchor from performing properly.
For many years, I cruised in a 60ft converted Scottish wooden fishing boat, and almost always used a fabricated plough, which was pretty much identical to a CQR. It performed perfectly, but it weighed 140 lbs, so not really comparable with average yacht anchors. With that boat, my second and third anchors were both Danforths, also 140lbs.
For my present 36ft ketch, my everyday anchor is a 20kg genuine Bruce, on an all chain rode. My second is a Fortress FX23, which has roughly the same dimensions as the 20kg Danforth, which it replaced. My third anchor, which is admittedly very seldom used, is a 20kg Fisherman. All of these anchors have their uses in different conditions.
I make no particular claims, or recommendations, about my choices, but I would say that rather than going out and buying the current most fashionable anchor, it is much more important to use all available information about the proposed anchoring site, before dropping the anchor.
That's a very good choice of anchors!
sarabande
6 May 2005
Intriguing info, TNLI. I came across the "kite" WW2 anchor while trying to retrieve info on your historical comment.
World War 2 Kite Anchors Found and Recovered - Beckett Rankine
It's noteworthy that the designer, Alan Bekkett, indicates that anchors of that time could hold with a power about 10 times their weight. His lecture notes on the design of the 330kg anchor are
development-of-the-kite-anchor-by-allan-beckett.pdf (beckettrankine.com)
and the weight (mass) function observation may have led to the Bruce being used on oil rigs first. The kite is fascinating because, amongst other features it has a sealed air chamber to lift the body in such a way as to angle the point into the seabed.
BTW, here's a pic of a "claw" anchor.
which leads me to suspect that "claw" seems a good image word to choose when naming an anchor
TNLI
20 Jul 2020
The Bruce Anchor Sets Best - Practical Sailor (practical-sailor.com)
Bruce fans wil like that article, although the thing that amuses me about all the modern anchors is that is you look at holding power and resetting, the Danforth is still top of the tables, which is why it's often omitted from tests. That article also mentions the Bruce performing well in rocks.
A lot of the advertising associated with anchors like the Rocna make you think that there has been some king of revolution in performance terms, when in reality nothing has really changed. The important thing is to select the right type of anchor for the type of bottom and conditions, rather than think that one type of anchor will do. I might have been called a CQR fan, but in real;ity I like the Bruce and Danforth nearly as much. What I do not like are anchors that get bent or rust, and most of the new modern anchors have got a problem with one of the other.
Boathook
5 Oct 2001
Surrey & boat in Dorset.
A lot of the advertising associated with anchors like the Rocna make you think that there has been some king of revolution in performance terms, when in reality nothing has really changed. The important thing is to select the right type of anchor for the type of bottom and conditions, rather than think that one type of anchor will do. I might have been called a CQR fan, but in real;ity I kile the Bruce and Danforth nearly as much. What I do not like are anchor that get bent or rust, and most of the new modern anchors have got a problem with one of the other.
Having had a danforth and now a rocna the rocna is superior as far as I'm concerned. It digs itself in so much quicker that you noticeably feel the boat stop. The rocna has also been a lot more difficult to break out.
john_morris_uk
3 Jul 2002
At sea somewhere.
A slightly bizarre test and conclusion considering several of the new generation anchors aren’t included. When was the testing done and the article written?
Neeves
20 Nov 2011
Sydney, Australia.
It seems to have been originally published in August 2,000 - which is why Rocna etc are not included (Rocna was brought to the public's attention in the 2006 anchor test). Many of the anchors are American (and I simply don't recognise them). Fortress introduced in the early 1990s (maybe late 1980s) is the most recent I recognise. Spade was introduced in the early 1990s but enjoyed terrible marketing (which has not changed much) and I doubt was available in America in 2000. The article was updated - but I doubt the testing was repeated (nor added to)
Linking the test is a bit like offering a link to a review of chart plotters, sail cloth, cordage or even yachts of the same vintage :). (and I chose the word vintage with care :) ).
The test might have been valid for the period (I'm far to young to know?) and for an American readership - many Practical Sailor articles are now slightly better focussed at an international audience.
Jonathan
srm
16 May 2004
Azores, Terceira.
Agree 100% with the first, something I have never experienced first hand. However, if you use any steel anchor enough eventually the protective coating will wear away around the fluke as sea bed sediment and rock is abrasive, with sand being the worse.
I found the Bruce Patent anchor good on the west coast of Norway as it could often find a rock edge to hook on to. However, its advisable to moor the boat back to the shore in the Scandinavian fashion to keep the pull on the hook. If the boat is allowed to swing it may let go as the direction of pull changes.
