Restoring fibreglass?
hunter_europa
19 Jun 2011
Argyll
Hi everyone,
I'm looking for some advice. The white fibreglass deck and cockpit on my hunter Europa is getting a bit old, I've tried polishing it but it never quite gets the finish that I'm looking for. I know that a 20+ year old boat will never look perfect but I know it can look better. As far as I can tell I've got three options and I would like your opinions on any of them.
1 - paint it, not too keen on doing that though.
2 - poliglow, although I've heard that in the longterm this isn't a good idea
3 - rubbing compound then polishing compound, then wax
I would really appreciate anyone's advice.
30boat
N/A
26 Oct 2001
Portugal
Or do as I do and leave well alone.Polishing removes a lot of material and sometimes the gelcoat is quite thin.Once the laminate starts showing through painting is the only solution.
yoda
12 Dec 2001
Tamar river, Devon
Option 3 but set yourself up with good quality products and the right buffing machine and mop heads. While over the years the gel coat will thin it is only a small amount that is removed if you use the right products and techniques. As somebody else has said once the laminate starts to appear there is little you can do except re-gel coat (possible and better done by a professional) or paint.
Yoda
hunter_europa
19 Jun 2011
Argyll
Thanks for your advice everyone. I think I will give the rubbing compound a try, I've seen starbrite on a few chandlers websites, would you recommend that brand?
richardbrennan
10 Dec 2008
It's a three stage process; you need to compound, then polish and then wax. I used 3M products which were excellent, the compound is called something like "Imperial Polishing Compound" the polish is something like "Finesse It" and the wax is "Protective Liquid Wax". The compound is not widely available in chandleries but can be ordered on line from "Carters Consumables". I also invested in a Rupes polisher which was expensive but about half the weight of anything else on the market and I also used 3M lambswool bonnets, white for compounding and yellow for polishing. I have now switched to Maguires wax, it seems to last longer than the 3m on my dark blue hull.
It's hard work but very satisfying!
VicS
13 Jul 2002
I have used Farecla, Boat-pride ?? and most recently Starbrite.
IIRC the Farecla was a bit coarser that the others, but I may not have used the correct grade. I have both grades of Starbrite rubbing compound (paste) I use the "heavy" grade only where necessary.
For years I used a two speed electric drill on its slow speed but I now have an inexpensive Silverline sander/polishing machine.
Toolstation have the polishing machine for £40 also the foam compounding mops to fit.
I expect Screwfix have the same or similar.
I polished with one of the Starbrite liquid polishes after compounding. I think I might try their "Boat wax" instead.
Before and after pictures:
saxonpirate
7 Jul 2007
Falmouth et la belle France
Definitely option 3. I always use Farecla. It's available in all grades and is used extensively in the industry. I always get it from a trade supplier, although I guess any good chandler will be able to get it for you. Good stuff...
VicS
13 Jul 2002
Mostly people are using the Farecla products aimed at the vehicle refinishing trade. For best prices, therefore, go to a vehicle paint suppliers ... that's how I bought my Farecla compound first time round.
Easier in the long run to simply buy what the chandlers I happen to be shopping in have on the shelf ( actually even bought the polishing machine from Force 4 )
William_H
28 Jul 2003
West Australia
Reconditioning f/g
As said the best option is cut back and polish however most boats that get to he age of fading gel coat also collect damage and evidence of filling holes etc. Eventually no amount of polishing will cover the repairs so you end up painting. Painting can be good but ruins the rough non skid areas by making them smooth.
In my case I went to repaint with 2 pack Polyurethane paint many years ago. It does not look like a new f/g boat anymore but it is easy to touch up and keep it looking smart if not brilliant. I use granules in the paint to get the non skid rough again. You will know when the time comes to repaint cos polishing just won't be good enough. good luck olewill
mhph
15 Feb 2007
Option 3 this may give you some ideas on how to do the job, http://www.youtube.com/watch?v=k9rwHVTjZkI there are other links form this on youtube, you can also pick up some fairly good electric buffers (silverline type) on e-bay from around £35 be careful not to burn the gelcoat though.
I like the look and action of the Shurhold dual action buffer/polisher ( ie movement in different planes).In doing some research (internet) I haven`t seen a UK available make with the same action.Does anybody have any info ?
billcowan
20 Mar 2005
Drumadoon
Agree, should avoid painting until the last resort.
but when you do, go for 2 pack polyeurithane paint, and dont stint on the prep. Polyeurithane doesnt adhere very well so needs a totally clean well keyed (scratched up) surface. apply with small fine wool roller and 'tip' off with soft brush. You get almost as good a finish as the original gel, but not as hard. so you have to touch up the scratches every couple of seasons
Lakesailor
15 Feb 2005
Near Here
Did you find the wool roller suitable? I started a boat with one and luckily started on the transom. The fall-out from the roller was awful.
I quickly went back to foam mini-rollers.
ghostlymoron
9 Apr 2005
Shropshire
Vic, I'd use what you used last times - the result looks great
