petem
Morning all.
I'd like to replace our old SMEV gas oven with a microwave / grill.
I'd assumed this was a simple project but it is looking trickier!
Problem number 1
Domestic microwaves that are designed to be fitted into a cabinet are invariably 60cm wide. I can find one or two that are 50cm but they are only microwaves (not grills).
Problem number 2
Stand-alone microwaves are rarely designed to be fitted in a cabinet and usually require c.20cm clearance at each side of the microwave (for ventilation).
Problem number 3
As you'll see from the below pic, the SMEV over (which is 50cm wide) has a lip / return at the front, which screws to the leading edge of the surrounding cabinet. I can't find a microwave fitting kit that has the same forward edge.
![Smev-Oven-Grill-30ltr__28702.1522739185_smev+oven.jpg Smev-Oven-Grill-30ltr__28702.1522739185_smev+oven.jpg](https://ybw-data.community.forum/attachments/97/97519-c309c56690519303288fae6db8c8cdeb.jpg)
Problem Number 4
The original Sharp microwaves and fitting kits that Fairline used are no longer available.
Has anyone solved this? Fabrication of a basic mounting kit is something that I can sort out, or I could reuse the surround from the old SMEV oven.
Problem number 1
Problem number 2
Problem number 3
Problem Number 4
