sailoppopotamus
I'm looking to replace my Silva S10.
I'm currently between Standard Horizon's GX1400GPS/E and Icom's M330GE. The SH is significantly cheaper (290E vs 380E, for the Icom including the flush mount kits). On the face of it, the SH is more appealing as it is much cheaper. However, it supports only GPS, whereas the Icom supports GPS, GALILEO and GLONASS and SBAS, which probably means that it's more accurate and less likely to not be able to get a fix. Furthermore, Icom's claim to have active noise cancelling leads me to believe that perhaps reception might be better. Would I be foolish to spend 90E more just on this reasoning?
A final, perhaps naive question: The Icom comes with an external patch antenna, whereas the SH has an integrated antenna. Is it necessary to install the patch antenna for the GPS to operate, or is there an integrated antenna inside the Icom? I'm mounting the unit on a bulkhead over my chart table (fiberglass boat) so would prefer as little clutter as possible (for what it's worth my phone gets a GPS fix just fine over there).
