Bosshogg
New Member
Hi, can anyone give any advice how to change the acrylic - polycarbonate windows in the patio doors of a beneteau 7 Antares 2007.
cheers Colin.
cheers Colin.
Try plastic sheets.com , phoned them this morning to price some sheets for the patio doors, they have all sorts of colours and sizes , I talked with ashleigh he was a great help.I cant give you any direct advice relating to replacement on your particular model of boat, however I am currently trying to source some 10mm smoked acrylic to replace the companionway hatch and washboards. It seems that due to the current "zombie Apocalypse" this is very hard to buy as manufacturers have been concentrating on supplying clear sheets for screens.
Thanks I will take a look later.I've no idea either but if it's aluminium frame it will either have clip in beads or is a wrap around frame.
Around the corner area may be plastic caps on the edges on the uprights. Under the caps will be screws which fix the sides to the top and bottom. That's the way domestic patio doors usually go together
If they are the same design on the Antares 760 then the instructions on how to remove the doors are here Sliding Doors instructions.docxHi, can anyone give any advice how to change the acrylic - polycarbonate windows in the patio doors of a beneteau 7 Antares 2007.
cheers Colin.
