Repairing a dinghy
Rum_Pirate
23 Aug 2004
A tiny Island, Caribbean
I have an Achilles Category D Model LSI-88 dinghy.
It has three holes.
One in the bottom sheeting,
Two in the tubes.
I have some patching material that came with it.
Which glue do you use patch the holes (each about same size) ?
Concerned if patching bottom sheeting do you apply patch internally or externally ?
When patching the tubes do you apply patch internally or externally ?
If internally, I suspect a bit of riffling is necessary. Anyone able to explain how to do that 'fiddling' in getting and keeping patch(es) in position ?
Hole in tube 1" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Name . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Hole in bottom sheet 2"
General view with (white?) inflatable keel) . . . . . . . . .General view with inflatable base
B27
26 Jul 2023
The proper glue to use is a two-part contact adhesive, you get a tin of glue and some 'activator'.
It's a different glue for PVC or Hypalon dinghies.
The glue is a about £20 in the UK.
You also want some MEK or other solvent.
Rum_Pirate
23 Aug 2004
Internet - how accurate?
3M 5200 works. i put a patch on my avon 20 years ago and it's still firmly stuck. i also made a recent discovery; gorilla super glue (not the regular gorilla glue) which comes in tiny tubes holds really well too.
have a read here.
Not sure what to use (if I can't get the proper stuff) .
Hypalon Dinghy Repair - Cruisers & Sailing Forums.
Tranona
10 Nov 2007
It is Hypalon, so you need glue for that not for PVC. The tube is repaired on the outside the bottom panel on either side or maybe both.
The Bostik product in your link plus toluene to clean it is the correct advice. No experience of using 5200.
