Rum_Pirate
I have an Achilles Category D Model LSI-88 dinghy.
It has three holes.
One in the bottom sheeting,
Two in the tubes.
I have some patching material that came with it.
Which glue do you use patch the holes (each about same size) ?
Concerned if patching bottom sheeting do you apply patch internally or externally ?
When patching the tubes do you apply patch internally or externally ?
If internally, I suspect a bit of riffling is necessary. Anyone able to explain how to do that 'fiddling' in getting and keeping patch(es) in position ?
Hole in tube 1" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Name . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Hole in bottom sheet 2"
General view with (white?) inflatable keel) . . . . . . . . .General view with inflatable base
It has three holes.
Two in the tubes.
