Removing Sealant
tmax
24 Nov 2004
Have removed a wooden plaque from the externel cabin bulkhead and am left with a large (8" dia) patch of clear silicone selant, the edges peeled off but the rest is firmly stuck to the gelcoat. Any suggestions on how to loosen/remove it.
Thanks.
longjohnsilver
30 May 2001
I've used one ofthose scrapers with a stanley knife blade in it which you can get cheaply from DIY stores, usually used to clear paint off windows.
Be careful not to scratch the gel coat. Once you've got most of it off you should be able to use meths or white spirit to clean the rest off. This method worked well for me.
andyball
1 Jun 2001
You can buy silicone remover ( a good buliders/diy shop).....try it on some hidden gelcoat first.....I know it removes silicone, but I'd hate it to remove your gelcoat too .
I have used some stuff called Silicone Eater Made by Ever Build Phone 0113255003.
I got it from Screwfix . There is no damage to my gelcoat.
Paul
