Remove mast/sails fulltime on a Westerly Centaur 26.
Gunblade
8 Apr 2026
Hi all,
I’m looking for some advice and opinions from people with experience of Westerly Centaurs or similar boats.
I’ve recently been looking at a Westerly Centaur 26 and my plan is to use it primarily for motoring rather than sailing. I don’t currently have any sailing experience, so I would not be using the sails at all.
Because of that, I’m considering removing the mast and sails completely and running it more like a small motor cruiser.
My intended route would be coastal from Fleetwood down to Dover, then crossing the Channel and heading straight into the French canals system.
The boat would have a diesel inboard as the main propulsion, and I’d also carry a spare outboard as an emergency backup.
My main questions are:
  • Would removing the mast make the boat more stable or suitable for coastal passages and a Channel crossing, or does it actually make little difference?
  • Is there any downside to removing the mast completely rather than just lowering it and keeping it onboard?
  • For someone not planning to sail at all, is this a sensible setup for this kind of trip?
  • Would you consider this safe and practical for UK coastal cruising and a Channel crossing?
I’m trying to keep things simple and reliable, but I also don’t want to make a decision that could negatively affect safety or handling in rougher conditions.
Really interested to hear real-world opinions, especially from anyone who has motored a Centaur long distances or done similar trips.
Thanks in advance.
Hi all,
Thanks in advance.
Welcome to the forum
Doubt you will find anybody with direct long term experience of motoring a Centaur. Fine in the canals at low speed but not practical at sea as without the mast the boat will roll all over the place. If you want a motor boat buy one. They are fundamentally different in design from a sailing boat.
So, basically forget it. A Centaur in sailing mode is quite capable of doing what you plan as a sailing boat. Nothing difficult about learning to sail and in many ways much more suitable for your plans than a motor boat of similar size
