Remove corroded aluminum screws
jfkal
17 Aug 2001
Singapore
Anyone with a trick on how to remove aluminum screws corroded solid in aluminum mast? I tried: Heat, cold, WD40. Not budging :-(
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Hydrochloric acid dissolves the carbonate deposit that results from galvanic corrosion. It also attacks pure aluminium but your mast is made from an alloy that is far more resistant. Even so, take it easy with a few drops of acid at a time and wash copiously with water when complete .
See the article at the bottom of this page Corrosion
