Porthandbuoy
Sheolin had a removable inner stainless stay on which I could hank on a storm jib or heavy weather headsail (I have both). I removed it because it was difficult to stow, when not in use, and chafed against the mast or guardrails or spreaders or stanchions, depending how I secured it.
Now I'm thinking of reinstating it using Dyneema , Spectra or something similar. In use it would be tensioned by a Highfield lever. Anyone done that and was chafe a problem with piston hanks?
To stow it I was thinking of fitting a snatch block at the base of the mast, running the stay round that and up to the spinnaker pole ring. Under tension that should be quite tidy.
