Cardo
Our solar panels come with the standard connectors. Could someone recommend what deck connector to use with these?
Nedmin mentions a gland. What do you mean by that?
For example:
The hole is the same size as (or just slightly smaller than) the cable. You run the cable through the hole, then do up the three screws which pull the top and bottom halves of the metal together. This squeezes the rubber, which tightens around the cable forming a watertight seal.
Why is a gland recommended over a plug?
For example:
http://www.saltyjohn.co.uk/images/products/gland-out.jpg
Try googling "Index Marine Side Entry Cable Gland" this allows you to get the cable inside without it sticking up in the air like a conventional cable gland.
Looks neater and less vulnerable IMHO.
I wish I knew how to post pictures!
since it is a pretty bad idea to have a plug with exposed pins on the end of the cable from the panel..
Trouble is, we need a deck plug, not a deck socket, since it is a pretty bad idea to have a plug with exposed pins on the end of the cable from the panel.
