[2574]
Fitting a doppler radar. The data cable has 18mm plugs on both ends, nightmare to route through trunking and bulkheads. Has anyone cut and spliced? Any problems?
Thanks Paul. How about Wago connectors?Yes it can, solder and heat shrink would be best. Or you can cut it and fit something like RJ45 connectors.
Thanks. I know what you mean about clumsy - but my soldering skills are also clumsy, which is being polite!You could, little clumsy though.
Thanks for the guidance, I will have a good look at the shielding.I recently installed a Furuno DRS4D-NXT and had to cut the RJ45 connector off the Display end of the cable to get the cable thru.
My observations were:- the original connector was a Shielded RJ 45 not a standard version. The cable had a braided screen and drain wire that were soldered to the outer shield on the Shielded RJ45 plug.
It seemed that Furuno had gone to quite some effort to ensure the best possible continuity of the screen from Radome to Display Unit. I reconnected as they had done, all working.
Extending the cable is another matter. The beige coloured “connectors” as seen everywhere are used on UTP and do not in my experience connect the shield. Only the 8 conductors of the Cat5/6 cable.
Most Cat5e cables are UTP ie Unshielded Twisted Pair. There is available STP ie Shielded Twisted Pair. I have never seen a STP cable with the quality/density of shielding as was supplied by Furuno. From recollection the Furuno had only 4 conductors crimped into the RJ45 connector.
Maybe it would be wise to take a good look at how the screen is connected with those 18mm plugs
