boatone
Having previously owned a boat with a seacock and weedbox type filter I was a little surprised to find that the raw water intake for the AQD32's is via the leg and appears to have no way of being shut off 'sea-cock wise'. Also as the connecting hose inside the hull appears to have a lower end that is marginally on the water line any leaks could be a little dodgy! When wintering afloat with the previous boat I would shut off the seacock and pour 50/50 antifreeze through the weed filter with the engine running until the antifreeze showed at the exhaust outlet and found this very simple routine protected the raw water cooling side perfectly. Anyone know how to do this on the AQD 32's? Anyone know if its possible to mod the existing arrangement to fit an inline weed strainer inboard of the water intake?
Incidentally, in a previous post some weeks ago someone suggested that freezing was unlikely to be a problem with the boat afloat - definitely not so.... as I learnt to my cost with a damaged heat exchanger before learning the routine above.
boatone@boatsonthethames.co.uk
