Sans Bateau
Is PTFE tape the best product for sealing threaded joints? Seacock to skin fitting etc. Or is there something better I should use?
I've always used Sikaflex on skin fittings threads. Never leaks and does undo.
Can you still get "Boss White". I always used to use it for domestic plumbing (until I discovered compression joints don't need a sealant.
PTFE is fine but only as a lubricant, not a sealant itself
