Chris H
I wasn’t aware you could acid clean yourself, what’s the stuff called and what do you do with the run off ?IMO none of the coatings stick to the props.
Great if you don't use the boat but there is just too much energy being dissipated down there.
My solution is spend your time polishing the props etc.
Then lift the boat and do a quick acid wash.
I can get ours acid washed in the time that the rest of the boat gets pressure washed.
Before
And about 45 minutes later after a pressure wash and acid wash.
In Spain, we buy the acid from the local supermarkets
