lw395
And how many Countess 33s (OPs boat) might be fitted with one of those? - or any other yacht auxiliary?
Well none, but it shows the principle, if you are a engineer.
It shows how the taper is the bit that does the work.
It's not easy to find info about props without keyways on the net, but I've seen quite a few, mostly older.
Fair enough a keyway is the norm now, but its not the only way.
And it does little to reduce props falling off.
If anything, isn't that more common than it used to be?
