PCUK
You cannot do without a key. Is that clear enough? At some point the prop will free off' and spin on the shaft, could be hitting debris or just a violent move from forward to astern. You can use a nyloc nut and when it is fully tightened drill it and fit a split pin, or just use a standard nut and drill it after tightening. Castellations rarely line up exactly. Whatever you use you will definitely need a key.
