pissativlypossed
We have a strange high pitched whistling noise emenating from the stern of our boat, we are on shafts, and the noise starts when the shafts start to rotate, but it stops above 750 rpm. High speed running does not appear to be affected and the whistling is not present.
When we engage reverse the whistling is present but at a slightly different pitch and again up to about 750rpm.
The two main bearings are water cooled and are not getting hot and there does not seem to be any excessive vibration or movement in the shaft's.
The boat has done 105 hours and this noise has been getting progressivly louder the last 10 hours or so.
We do have Spur's rope cutters fitted.
The engines and gear boxes have just been serviced the engineer was happy that the problem was after the gearbox. The strange thing is that it is on both engines, I can understand if a cutlass bearing has gone where the noise is coming from, but 2 at the same time seems a little too coincidental.
Any ideas please?
Any ideas please?
