stelican
Why not tow the boat for that section of journey
could you not lift the leg right up then use a short leg outboard for that journey
Hi Wayne looking forward to the new thread , got quite addicted to your old thread had to check most days to see if you had done something else on the boat, hope you get some time to actually use your new boat when it’s done
The Norman has an outboard bracket and you have an outboard.
Congrats on your new project
When you say you’ll do something you do it!
Like I said before, it's an illness, an addiction and you seem to have it very badly. Have you considered AA? (Aquatics Anonymous). I hope not. Looking forward to following along on your latest endeavour and wishing you every success in the process. My repairs are seriously on hold as work continues at a hectic pace. Still, I'll have all winter to get her finished, by which time you'll probably have rebuilt the Titanic!
Best of luck with her and I have experience with outdrives/legs and not all good, so feel free to ask in the event that I can be of any help.
I am considering converting to shaft drive![]()
Now I know you are crackers![]()
Awesome Wayne. I really like the lines of your boat.
Has a sort of MTB look to it
Can the outdrive not be operated raised up a bit? Do the Enfields swing sideways or something?
My outdrive sits pretty much completely submerged. Just an inch or two above water at rest. I think it just depends on the boat/engine combo.I don't like the notion that the top of the leg is below the surface of the water. From my limited experience, just the leg itself should be submerged. The leg usually comes in an upper and lower section. The upper section houses the gears and if any water gets in there, it's not going to do much good
Hey Wayne. I'm totally on board and looking forward to seeing her reborn. I have a friend who gave a similar boat a makeover but cut away the rear cabin for extra deck space. Used mostly for fishing. Hope it all goes well without too many nasty surprises!
Better here with you tube links I think
