MILLPOND
I would like some advice please.
This winter I had a Sureseal dripless sterngland fitted to replace the ageing stuffing box on my 1992 Nauticat 33. I asked the engineer at the boatyard to fit the unit. He took the water feed to the unit from the oil cooler of the engine. First outing of the season all was well. When I went down this weekend though, pre-departure oil check revealed that the engine was full of water. The engineer had not installed a siphon break or vented loop in the water feed, so when the engine cooled, it sucked in sea water through the stern gland which siphoned up to water level.
I took 20 litres of emulsified water and oil out of the engine and changed the oil and filter four times. I also installed a siphon break in the water feed hose. The engine has been run for three trips of four hours, and the oil now looks cleaner than ever with no trace of mayonnaise! Hopefully the problem is solved.
Are four oil changes enough?
However, there is now another problem. When the prop shaft is running, there is a knocking noise coming from the stern-tube or cutlass bearing area of the hull. It is getting louder. On close examination the shaft appears to be slightly out of alignment and there is a tiny amount of lateral 'wiggle' in the shaft as it rotates.
I think there are two potential causes - either the cutlass bearing has been damaged during the stern gland installation, or the prop shaft is not correctly aligned with the transmission coupling. Either one is beyond my capability to fix. Before incurring the cost of having the boat hauled out, has anyone got any other suggestions? Is there anyway of checking shaft alignment with the boat still in the water?
Would you ask the engineer to fix this at his own expense? Should I go somewhere else - the track record of not installing the siphon break does not instil confidence.
Thanks for the advice.
