dlf
I am wondering if the mechanically minded amongst you could possibly offer some advice on the problem I am having with my Honda 5hp outboard engine (4 stroke). I purchased the engine from new 7 years ago and generally I don’t have any problems except when I run it for extended periods (approximately one hour or more). For some unknown reason the revs will suddenly drop off very quickly and then it just stalls. I am able to restart it but within twenty minutes or so the engine will stall in exactly the same manner. I have found that if I reduce the revs, it will run a bit longer but eventually it will stall. The longer I try to run the engine, the shorter the periods become between each stall and restart, until you get to a point where the engine barely runs at all. The oil is ok & the water cooling system seems to be operating fine. As I said early I don't have any problems during shorter running periods. Can anyone help or offer some advice?
