Can do. I used to pressure wash our non-slip areas until I noticed tiny bits where the gelcoat was chipped off. I don't do it now except on a low-pressure wide-spray setting /forums/images/graemlins/frown.gif
Don't do it, it will blast tiny pin prick holes where the gelcoat is thin.
you could use Oxyalic Acid but be very careful with it and wash off with running water.
I would go to the nearest caravan shop, they sell a cleaning paste that I found very good.
As per the above advice - I'd recommend you don't pressure wash gel coat. I've heard too many stories about damage to gel coat. I use a good scrubbing brush and Silky - available from most caravan shops at a very reasonable price.
Yards have been pressure washing boats for years ..... top and under.
I've been pressure washing all my boats ... albeit cheapo DIY machines - but still high pressure.
As to what I do .. first a good blow over with PW ... then a good rub with Cillit Bang Lime and Rust Bog cleaner ... wash off ... and a good PW again to remove all traces of Cillit.
This year I didn't finish of as I should have done .. that is with a good polish to keep the gel smooth and stuff not stick to it .. so this year I have ended up with mucky topsides again.
So when I lift out ... which due to engine in bits - will probably be in couple of weeks - my Bosch PW will be dragged out and she'll get blasted as usual.
Of course though - my boat and previous are built like battle tanks - old MAB's ... built like out-houses !
Speaking as someone with a 1972 boat whose gelcoat is on its last legs, I think I'd be quite cautious about using a good pressure washer on my decks. I too have the moulded-in non-slip bits and they are really just pure gelcoat because the fibres can't follow the fine corrugations of the non-slip pattern. I have used one before but as soon as there is the slightest weakness in the top skin, it can flick a little piece of gel off and then the water goes down into the laminate - after which, the problem only ever gets worse!
I'm lucky you see ... painted non-slip ... and to be honest it needs blasting off !!
Oh and to ingress of water into where gel has chipped of ... why do people think that a pressure washer will put wtaer in that normal exposure wont over time ? In fact water is able to get in whether under pressure or not ... exposed fibres will wick the water in as fast as a rabbit gets .......
The only reason IMHO that a PW is not to be used is if you do have gel that will be driven of by the jet ... otherwise its clean it up Jim !!
I was told that CIF etc can leave a residue, amoonia I think, that can get into the gel coat. I think you have to take a view on these things. As long as you don't do it all the time it is probably okay.
I can't wait until the future when you will be able to buy a little robot that carefully cleans your boat when you are not there... /forums/images/graemlins/smile.gif
You can already buy a system that keeps your boat effectively out of the marinas water by "bagging" it alongside ... developed for those boats that sit alongside waiting for owners to remember they have a boat !!
I wasn't saying that the pressure washer forces water into the laminate DURING the pressure washing operation! (Although it might well force a little bit in)! What I said was that AFTER the little bit of gelcoat has been knocked off, water will get in. What I probably should have added was ..."over time, by any means it can"...
