Refueler
hybrid seems to work well enough for cars, maybe the objections to hybrid yachts consists of more than mathematics, which appears to work in favour of one, but against the other.
maybe its ignorance?
im sure there is an engineer out there capable of deigning a funnelled turbine capable of being deployed at the stern
The Car hybrid is a poor example to use for a yacht system .. the Car system has recovery of energy to the battery system when running purely on fuel engine ... then when called on - the E-Motors are mostly supplemental to the fuel engine.
How would you do that on a yacht ?
OK .. Trains / Ships ... Diesel-Electric .. why ? Others have mentioned the efficiency aspect ... diesel is a workhorse that performs best when run at high loads and RPM ... it has good torque - but only when engine is at reasonable RPM, at lower speeds it fails ... but E-Motors torque is there at low and medium speeds ...
This is why Diesels on trains have typically been married to Hydraulic or Electric drive.
Ships are a slightly different proposition as 'Motor Ships' are prone to vibration - Boy - you have to see it to believe it !! .. so a combination of the E-Motor 'torque' advantage and that the diesel power source can be run at most efficient / least vibration ...
