ylop
underway - but not at anchor?the turning prop was something i noticed on my competent crew vessel. my own has a folding prop so i never noticed it, but the churning sound was very much evident on the training vessel
I've barely been anywhere all year. Keep just heading out of the same river, sailing round in circles for a few hours and going back to the same river.Most people WITH Diesels never go anywhere!
You speak for yourself. You're the one who's complaining that their anchor chain wears away because it's always on hard sand and coral.Most people WITH Diesels never go anywhere!
Where do you keep your boat in between sails?You speak for yourself. You're the one who's complaining that their anchor chain wears away because it's always on hard sand and coral.![]()
I anchor every night, and sometimes several times a day. I would be bored rigid crossing crossing an ocean. We sail between meals.Where do you keep your boat in between sails?
Done an Atlantic crossing this year. What did you do![]()
i think a crucial point you are missing, is torque.Absolutely not, there’s plenty of big currents here - but:
1. We don’t tend to anchor of moor in the areas with 3+knot currents. My mooring has about 1knot at peak springs
2. Most systems for generating power by towing a prop through the water seem to need around 4 knots to be able to generate power (a prop will turn with no load on it but as soon as you connect an alternator it is effectively a brake).
3. Even if you had a system/location when it would work the boat will tend to move to minimise its drag, ie turn until there is least resistance on the turbine! The wind makes this even harder to manage. Fixed tidal power gen needs “forced” into the flow.
If you want to see this - if you have a non-feathering prop when under sail in neutral you can see/hear the prop spinning. You won’t normally notice this on a mooring / anchorage / marina - and that’s with no load on the prop.
no i never noticed it at anchor, because the prop needs to be turning for the blades to extend.underway - but not at anchor?
Your unlikely to be like most people. You are going places.I anchor every night, and sometimes several times a day. I would be bored rigid crossing crossing an ocean. We sail between meals.Each to their own.
I was merely, and not too seriously, responding to your questionable statement that "Most people with diesels never go anywhere".
crossing oiceans scare the sh*t out of me, coastal britain can be quite scary enoughYour unlikely to be like most people. You are going places.
Crossing oceans is never boring. Sometimes I wish it waswhen you do it with just a couple on board, there is always plenty to do.
No im not missing torque or failing understand how gearing works. Im mostly telling you it is possible to get electrical power as the boat is sailing along - that’s not just theory there are commercial system that do it.i think a crucial point you are missing, is torque.
current has plenty of it, and with torque you can gear up to get the revs your system needs to produce useful power.
you dont need fast speeds at the paddle, just at the alternator/generator.
In fact by definition exactly that! And salt water a little more…water has a mass of almost 1kg per litre,
Yes that’s why there are tidal power projects off the Scottish coast. But what you are missing is that they are fixed installations which then rotate into the tidal stream.depending on the surface area of your paddle, thats a shit ton of powerful force going to waste if you are not making the most of it.
There’s a variety of engineering reasons, both proper fluid dynamics but also practical realities - sea water is incredibly corrosive; fouling much worse at sea and those massive forces have the ability to rip your paddle wheel to pieces especially in a storm. Servicing and getting power to/from marine installations is much harder than on land and whilst we now do a lot of wind stuff offshore we cut our teeth where all you needed of do was climb a ladder…. But despite all this there are systems in real world use both for grid electrical production and power gen on yachts.air on the other hand ha practically ero weight per litre, but people eem to consider a wind turbine a useful item to expend resources on?
make no sense to me
Yes! But what a change. Would I have been able to motor 90 miles (through 2-2.5 metre waves for 60 of those) at 6kts. with a silly little electric motor. Now I have a broken femour I can use my boat as a motor boat & motor long distances of up to 150 miles within my 24 hour SH insurance limit if I felt so inclined. I don't - but Dover to Dieppe is certainly on the cards next year.But nobody has ever suggested that you would be forced to (although you have had to replace one diesel engine already).
Waste of money buying a folding prop to get another half a knot thenNo im not missing torque or failing understand how gearing works. Im mostly telling you it is possible to get electrical power as the boat is sailing along - that’s not just theory there are commercial system that do it.
Generally the wet bits are quite safe, it's the crunchy bits round the edge that are the problemcrossing oiceans scare the sh*t out of me, coastal britain can be quite scary enough
Electric propulsion is very relevant in the PBO market - not least because other than expensive new builds, the majority of yacht electric drives have been DIY fitted in old boats whose diesel engine is end of life. (Sailing Uma was an early example, but I know of many more)
It is not for everyone, but for some boats and usage patterns it is worth considering.
Perhaps you need to be more open minded?
I write a little for PBO and not really for the little dosh I get (the day job is sadly not boaty), more to make me write up the tinkering projects I have undertaken. I bumped into a lovely chap on the boat on the weekend who was suffering with stiff roller furling gear, I sent him my text around my experience with my Selden roller furling gear which started at hate when I purchased my boat, and has ended at delight and wonder. Without the magazine I would never have written it up. Without the magazine it would never have been published too give others this practical advice.
I have another thread around rebuilding my raw water pump of my D2 55 - if it wasn't for the magazine I would probably never write this up - I started the process tentatively this weekend (I got two sentences in before one of my children leapt on me!).
Boating, even practical boating, is a broad church, and the editor and staff at PBO need to try and walk a tightrope of dealing with all their readership. If we grumble about the bits we don't like and stop buying and supporting them, these magazines will die and we won't get the bits we do like.
