maxi77
Umm - how do you decide the required current carrying capacity to size the cable? As I implied earlier, with a heavily discharged windlass battery and fully charged 'daisy chained' battery the charging current could be very high when the VSR closes.
Indeed, and on my Bongo I actually use the VSR to switch a heavy duty relay, mind you though as long as you protect the more sensitive bits of the system the periods of high current will be relatively short and I would not plan on using the windlass without having the engine running any way so I would not expect to have to deal with any more than the alternator output which is presently 35 amps on my present set up and will probably rise to 70 amps thiis year.
